[GRASSLIST:5325] Re: Compiling grass5.0.0
Piero Cavalieri
grasspiero at tiscali.it
Fri Jan 17 05:50:42 EST 2003
Glynn Clements wrote:
>Sjors wrote:
>>I'm wondering if anybody tried compilng grass5.0.0 under redhat8.0. I seem
>>to get a lot of errors.
>What errors, exactly?
>>Is the problem gcc3 and should I revert to gcc 2.98?
>There are a few problems with gcc 3, primarily related to the fact
>that it seems to default to C99. The result is that files which define
>a function called round() fail to compile. However, most of GRASS5
>should still compile...
...yes it is (on grass5.0.0pre4). I tried with gcc3.2 and I had
'only' these compile errors:
GRASS GIS compilation log
Start of compilation: Fri Jan 17 11:05:50 CET 2003
Errors:
Compilation error in module: src/imagery/i.class (ignored)
Compilation error in module: src/imagery/i.ortho.photo (ignored)
Compilation error in module: src/imagery/i.points (ignored)
Compilation error in module: src/imagery/i.vpoints (ignored)
End of compilation: Fri Jan 17 11:19:29 CET 2003
DONE generating GRASS GIS binary code
If I remember I had these, also with gcc2.96.
