[GRASSLIST:868] Re: r,stats(In GRASSLinks)
Shinichiro HAYASHI
forest at bres.tsukuba.ac.jp
Thu Jul 31 15:03:25 EDT 2003
Thank you for your adivise, SWlab.
>> r.stats -aql fs="^" input=$GRASTER1,$GRASTER2 > $TMP_PATH/stats.$$
>> > sh: line 1: cd: HOME not set
>> > WARNING: can't read range file for [landuse in PERMANENT]
>> > ERROR: r.stats: can't read range for [landuse]
>> > Why Can't r.stats open range file?
>> because HOME is not set ? Check the state of the variable.
I tried to write in /*/grasslinks/prog/reporter as follows.
HOME=/home/grass/grasslinks
But there is still a messeage in Apache error log.
1) When does "r.stats" demand variable "HOME"?
2) Where do I write variable "HOME" to let "r.stats" work?
Please give me suggestion.
Thank you in advance.
Sincerely yours.
$BNS(B $B??0lO:(B <forest at bres.tsukuba.ac.jp>
$BC^GHBg3X at 8L?4D6-2J3X8&5f2J at 8J*7w;q8;2J3X at l96(B
$BN.0h4IM}8&5f<<(B $B at 8G@Eo(BE104$B!!(BTel&Fax 0298-53-4897$B!!(B
$B at 8J*;q8;4D6->pJs%7%9%F%`(B(bres) $B%7%9%F%`%9%?%C%U!!!!(B
http://ryuiki.agbi.tsukuba.ac.jp/~forest
