[GRASSLIST:6204] Re: nviz initialisation
    Glynn Clements
    glynn.clements at virgin.net
    Wed May  7 14:59:10 EDT 2003
Jan Hartmann wrote:
> I just compiled Grass5.0.2 as a non-root user (i.e. with all binaries
> and libraries installed in my $HOME directory). All suporting packages,
> like Mesa and TclTK are also installed in $HOME. Everything works
> beautiful, except nviz. When I call it from the tcltk interface, I get a
> popup for specifying the input maps, but after that an error message
> pops up: "/home/.../grass5/tcltkgrass/main/pause: nviz: command not
> found". Before I start delving in the source code, has anyone an idea
> how to correct this? It's probably a trifle.
It appears that NVIZ failed to compile; error.log should confirm this.
The actual error message(s) will be in the output from "make"; if you
didn't redirect it to a file, re-run make and save the output, e.g.
"make &> build.log" (re-running make doesn't take long if everything
is already built).
Glynn Clements <glynn.clements at virgin.net>
