[GRASSLIST:6210] Re: Solaris 9 Build Problems
Glynn Clements glynn.clements at virgin.net
Thu May 8 07:23:48 EDT 2003
Ade Fewings wrote:
> It is highly possible [indeed likely] that i'm doing something silly,
> but i'm having trouble building Grass on a Solaris 9 Sparc box.  I have
> installed the required packages having built them with GCC3.2.2.
> Everything is in /usr/local/....
> The problem i have is with the configure script.  It all looks good
> until the following happens.....
> configure: error: *** Unable to locate GD library.
> I have successfully built and installed the latest version of libpng and
> the lib files are in /usr/local/lib and the headers are in
> /usr/local/include.  Can anybody help with this output from the
> configure script?
Do you have the GD library? If not, either get it from:
	http://www.boutell.com/gd/
or use the --without-gd configure switch (this will inhibit building
the PNG driver).
Glynn Clements <glynn.clements at virgin.net>
