[GRASSLIST:6240] Re: Solaris 9 Build Problems
Bill Sneed
bsneed at midcoast.com
Fri May 9 20:04:09 EDT 2003
Ade Fewings wrote:
> checking for gdImagePng in -lgd... no
> checking for gdImageGif in -lgd... no
> configure: error: *** Unable to locate GD library.
> I have successfully built and installed the latest version of libpng and
> the lib files are in /usr/local/lib and the headers are in
> /usr/local/include. Can anybody help with this output from the
> configure script?
The most obvious question is: Have you installed the GD library? If you
have, did you install it from the the Auxillary Software that came with
Solaris9? I've found that a lot of the "linux" software included by Sun
on the Installation DVDs goes into odd places -- places you'd never
think to look on a Intel/Linux setup....I'm new to Solaris so I'm using
the "find" command a lot!
I'm at home at the moment and not near a Solaris9 w/s so can't give you
more details from memory...
....bill sneed, prospect, maine.....
