[GRASSLIST:31] Re: Grass and Xwin32
Andrew
selkiesdad at comp10680.potsdam.edu
Thu May 15 08:07:05 EDT 2003
I used the StarNet X-server evaluation version and the detailed
instructions on the Grass site under Win 2000 SP3 and everything worked
first try. I also got the full-screen XFree86 server working with the
appropriate instructions on the same Grass information page. I burned a
CD with the necessary files and the detailed instructions I followed to
act as a guide for future attempts.
Christian Blumer wrote:
> Does anyone has any experience in running Grass on a PC through Xwin32
> or exceed?
> I installed Grass on linux and try to run it through Xwin32 on my PC.
> The problem is that I cannot get the graphical window by tcltkgrass&
> command. It appears and get blocked.
> Christian
