[GRASSLIST:32] Re: mapset creation (and can't search archives?)
Kirk R. Wythers
kwythers at umn.edu
Thu May 15 09:47:59 EDT 2003
If I read the man page correctly (always a big if), g.gisenv will only
do me any good once I have the MAPSET created. My first problem is the
under the LOCATION I made, I have only one MAPSET (PERMANENT). I want to
create several MAPSETS, but I can't find how to simply create a new
MAPSET.
Here's a scheme of what I'm looking to do:
LOACATION n_mn
MAPSETS PERMANENT lake_access acquisition_survey timber_survey
So... I think what I'm after is under the directory
~/grassdata/locations
I want the directories: lake_access, acquisition_survey, timber_survey
Can I simply use mkdir to create them, then use g.copy to move data into
them?
Kirk
On Wed, 2003-05-14 at 22:44, H Bowman wrote:
> If you are working with multiple mapsets:
> g.gisenv set="MAPSET=something"
> will be very useful to you for switching mapsets mid grass session.. The
> CVS version is a bit better at this than the 5.0.2 version.. still isn't
> 100% yet though.
Kirk R. Wythers Department of Forest Resources
Tel: 612.625.2261 University of Minnesota
Fax: 612.625.521 1530 Cleveland Ave. N
Email: kwythers at umn.edu Saint Paul, MN 55108 USA
