[GRASSLIST:232] Re: NEWBIE: GUI problem
Alexandra Panton alexpanton at btinternet.com
Tue May 27 16:24:14 EDT 2003
Working now, thank you all so much :)
Alexandra Panton
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
Behalf Of Edmund Blackadder
Sent: 27 May 2003 20:54
To: grasslist at baylor.edu
Subject: [GRASSLIST:231] Re: NEWBIE: GUI problem
first try t set the GRASS_WISH enviromental variable
usually the wish is in /usr/bin
All this provided that u have installed the tcltk rpms. Tcl/Tk is
needed for the GUI.
So, check your /usr/bin and usr/local/bin.If u find the "wish", set the
above variable. If uoy find something like wish8.4 set a link.
Konstantinos Theofilis
On Tuesday, May 27, 2003, at 08:04 PM, Antonios Christofides wrote:
> alexandra panton wrote:
>> ok, I am new to grass and kinda new to linux so please bear with me
>> :) I
>> have installed grass on the linux redhat 9 distribution when i start
>> it
>> i get the following error message:
>> [ "wish" appears to not be installed ]
> You need to learn and become very comfortable with installing software
> packages on your system. On RedHat systems you use the rpm command to
> install and uninstall packages. You need to insert your RedHat
> installation CD and type *something like*:
> # mount /cdrom
> # rpm -Uvh /cdrom/RedHat/RPMS/wish*.rpm
> Also read the rpm manual: "man rpm"
