[GRASSLIST:1710] Re: CE characters and vector colours
Glynn Clements glynn.clements at virgin.net
Sat Nov 8 18:50:32 EST 2003
Miha STAUT wrote:
> Last nihgt I had to plot some text labels on a map. The problem was that my
> labels contained also Central Europan characters which did not plot at all.
> I am sure there exists a solution to this problem.
Which program? ps.map? d.text? d.text.freetype? d.label?
ps.map only supports ISO Latin-1 (aka. ISO-8859-1). 5.0.0-pre3 and
earlier completely ignored the encoding so, if you have a printer (or
copy of Ghostscript) with a Latin-2 font[1], using -pre3 may work.
[1] and you can figure out how it's encoded; I wouldn't rely upon it
being ISO-8859-2; PostScript's default encoding isn't ISO-8859-1, but
something which it calls StandardEncoding[2].
[2] which is rather an odd name for an encoding which isn't remotely
standard; AFAICT, nothing other than PostScript uses this encoding.
If d.text.freetype was built to use iconv (look for HAVE_ICONV_H in
config.h), you can use any encoding which is supported by iconv
(subject to the font having the relevant glyphs, obviously), via the
charset=... option. If it wasn't built to use iconv, you're limited to
ISO-8859-1.
I don't think that the GRASS fonts (used by d.text, d.label etc)
support Latin-2. Actually, I don't think that they support Latin-1
either, just ASCII, Greek and Cyrillic.
Glynn Clements <glynn.clements at virgin.net>
