[GRASSLIST:1725] Point data from dxf file.
michele.rocc at libero.it
Mon Nov 10 11:27:59 EST 2003
Trying to inport point data from dxf files in grass5.0.3, I supposed to use v.in.dxf and made a selection for a specific layer (containing the points I need to import into grass).
The only way to select layer seems to be using the "lines" options, layers are recognized but points are displaied as vertical straight lines.
Is there another way to import those features?
Thanks, Michele.
