[GRASSLIST:1726] successful OSX10.3 build with caveats
Byron Amerson
byronea at u.washington.edu
Mon Nov 10 12:02:18 EST 2003
Hi there,
I have successfully built grass5.0.2 on my imac running osx 10.3.
the last lines of the make output I paste below to ask if there is a way
that I can patch or build the components that did not get compiled. I
also am curious to know if any of these broken bits are integral to a
reasonably fully functional build of grass? I compiled without dbm because
no matter what, compile could not see my gdbm.dylib even though it was
there plain as day. I also built without GLw and NLS, cause I could not
find any info about what they were and did not know how to proceed with
them. Gdal is built without python or odbc support.
any insights or tips would be great. Thanks
here is the make output:
GISBASE=/usr/local/src/grass/grass5.0.2/dist.powerpc-apple-darwin7.0.0
MACHINENAME=`uname -n` /bin/sh src/CMD/generic/POST_INSTALL.sh
cp:
/usr/local/src/grass/grass5.0.2/dist.powerpc-apple-darwin7.0.0/etc/digcap.sample:
No such file or directory
GRASS GIS source code compiled.
Compilation error in module: src/general/g.region (ignored)
Compilation error in module: src/imagery/i.points3 (ignored)
Compilation error in module: src/mapdev/v.digit (ignored)
Compilation error in module: src/mapdev/v.in.gshhs (ignored)
Compilation error in module: src/mapdev/v.mkquads (ignored)
Compilation error in module: src/mapdev/v.proj (ignored)
Compilation error in module: src/misc/m.kappa (ignored)
Compilation error in module: src/misc/m.proj2 (ignored)
Compilation error in module: src/raster/r.in.doq (ignored)
Compilation error in module: src/raster/r.in.gdal (ignored)
Compilation error in module: src/raster/r.mapcalc3 (ignored)
Compilation error in module: src/raster/r.proj (ignored)
Compilation error in module: src/raster/r.sun (ignored)
Compilation error in module: src/raster/r.sunmask (ignored)
Compilation error in module: src/raster/r.tiff (ignored)
Compilation error in module: src/raster/wildfire (ignored)
Compilation error in module: src/sites/s.proj (ignored)
Compilation error in module: src.garden/grass.postgresql (ignored)
Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
* In case of errors please check following web page for hints:
http://grass.itc.it/grass5/source/compilation_hints.html
* Install GRASS with (possibly as root)
make install
cp -f error.log error.log.powerpc-apple-darwin7.0.0
Byron Amerson
MS student
University of Washington
Department of Earth and Space Sciences
