[GRASSLIST:1428] Re: r.in.tiff
Richard Greenwood Rich at GreenwoodMap.com
Tue Oct 7 13:12:18 EDT 2003
At 12:40 PM 10/7/2003 -0400, you wrote:
>Hi every body, I want to create a mapset from a scanned map. I allready
>created the location and mapset with the 'xy' coordinate system, and
>then tried tu run r.in.tiff (it is a tif image). But all I get is a
>black display, even though I can see the created raster file in list of
>rasters. After that, I did run r.support, but have to confess didn't
>really know what I was doing... and I still see the black display. Can
>any body advice me which other command I should use or what I am doing
>wrong? I am not shure about the image, I guess it is not a geotif and
>just a palin tiff.
Try using r.in.gdal -oe instead of r.in.tiff The set your region to your
imported  tiff with g.region rast=imported_tiff.
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
