[GRASSLIST:1454] Re: mv: can't stat source(on GRASSLinks)
Bernhard Reiter
bernhard at intevation.de
Thu Oct 9 06:29:58 EDT 2003
On Thu, Oct 09, 2003 at 07:14:19AM +0900, Hayashi Shin-ichiro wrote:
> I executed GRASSLinks from web browser.
> But GRASSLinks doesn't work.
> In Apache error log
> mv: can't stat source /home/grass/grasslinks/gamahara/grasslinks1/UNLOCK
> mv: can't stat source /home/grass/grasslinks/gamahara/grasslinks2/UNLOCK
> mv: can't stat source /home/grass/grasslinks/gamahara/grasslinks3/UNLOCK
> mv: can't stat source /home/grass/grasslinks/gamahara/grasslinks4/UNLOCK
> mv: can't stat source /home/grass/grasslinks/gamahara/grasslinks5/UNLOCK
> I think that
> in grasslinks/prog/grass.cmd
> if mv -f $location$locnumber/UNLOCK $location$locnumber/LOCK
> doesn't return status value.
> My question is
> 1. Why doesn't "mv" command return status value?
Note that "stat" here means the unix system call stat()
which gets the file status. So mv basically cannot find or access
the file in question.
I don't know details about GRASSLinks, but maybe me hint
helps you to further analyse the situation.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20031009/5ddb63b3/attachment.bin
