[GRASSLIST:1461] Re: Exporting TIFF images
Glynn Clements
glynn.clements at virgin.net
Thu Oct 9 16:03:05 EDT 2003
M. Beth Wilkerson wrote:
> I have a raster map in GRASS 5.0.2 that was generated by importing 4 GTOPO30
> tiles. Now I would like to output this raster map as a TIFF file with 8-bit
> color. I tried using
> r.out.tiff -p -t -v input=rastermap output=tifmap
> However, when I submit this command, I get the following error:
> ERROR: Color map for palette must have less than 256 colors for the
> available range of data
> Note that if I execute the same command without the "-p" option, I can
> successfully export a TIFF file with 24-bit color.
> Can someone tell me how to "downsize" my number of colors so that I can
> successfully export a 8-bit color TIFF image?
r.rescale -z input=oldmap output=newmap to=1,255
Glynn Clements <glynn.clements at virgin.net>
