[GRASSLIST:1376] Re: Please, help me on r.recfity
Ivan Marchesini
marchesini at unipg.it
Mon Sep 29 03:42:24 EDT 2003
Dear Yasin...
I mean that when you use i.target you have to specify a location (UTM, or
lat-long or other) where the results of i.rectify will be put.....
so after you start i.rectify you have to change location and go to the UTM or
Lat.Long location, where, at the and of the process i.rectify, you will find
the rectified map....
I hope this help you.....
Bye
Ivan
Alle 05:52, domenica 28 settembre 2003, Alip.Yasin ha scritto:
> Dear GRASS Users
> Dear Sir Hamish, Ivan Marchesini
> Thank you very much for your help.
> >>Are you looking in the LOCATION which was set with i.target? You'll
> have
> >>to exit GRASS from the XY location and restart in the target
> (e.g.lat-lon) location.
> Actually I did looked in the same location which I set in the i.target for
> my i.rectified raster file.
> r.in.gdal ( XY location)
> -> i.group
> -> i.target (the same XY location)
> -> i.points
> -> i.rectify -> " You wil receive mail when i.rectify is complete"
> -> g.list (in the same XY location)
> -> no raster file which I named during i.rectify
> Are there the possibility that command i.rectify did not did the work?
> Or it is not good to use the same location as the i.target location?
> sincerely
> Ghalip Yasin
> Tsukuba University, Japan
> s01k154 at shako.sk.tsukuba.ac.jp
Ivan Marchesini
University of Perugia
Italy
