[GRASSLIST:3095] Re: GRASSLIST digest 1338
Michael Barton
michael.barton at asu.edu
Mon Apr 5 02:16:45 EDT 2004
On Sunday, April 4, 2004, at 10:01 PM, Multiple recipients of list
wrote:
> From: "Colin Nielsen" <nielsen at myrealbox.com>
> Date: Sun Apr 4, 2004 10:05:18 AM America/Phoenix
> To: GRASSLIST at baylor.edu
> Subject: [GRASSLIST:3091] Xtent Modelling (wieghted Thieseen)
> Does anyone know of a way to rank sites so that the theissen polygons
> are larger around higher ranked/weighted sites? I don't see any
> weighting/ranking option in the s.voronoi module. Any ideas?
> -Colin
This is not how Thiessen polygons work. They simply divide up space by
evenly dividing the distances between points. What you want to do is
interesting, but different. And I'm not sure it would work since the
polygon vertices are tied to the distances between a point and all the
nearest surrounding points.
v.bubble creates circles around points with a radius proportionate to
the values of a specified variable (e.g., a weighting variable). The
s.territory module also might do what you want. Alternatively, creating
a surface (e.g., with s.surf.rst) using the weighting varible as the
z-value might also serve your purpose.
Michael Barton
