[GRASSLIST:3134] RE: can't display DGN
tatel tatel at euskalnet.net
Sun Apr 11 14:35:13 EDT 2004
Many thanks for you help. Unfortunately, still I can't display. v.info
shows bad region limits (see below). Could the mistake be about bad
region settings while importing?
Thanks again,
Roman
import process follows
g.region n=45N s=37N w=10W e=5E
v.in.dgn - all defaults accepted
This outputs a lot of warnings about complex element header ignored,
complex elements parts written
Next I run v.support - all defaults accepted
###output for v.support-topology########################
Selected information from vector header
  Organization:
  Map Name:
  Source Date:
  Orig. Scale:   0
  Snapping threshold    0.00
   No snapping will be done.
     Reading Vector file 100%
     Building areas 100%
     Building islands (no islands present)
     Attaching labels
Failed to attach an attribute (category 2) to a line.
Failed to attach an attribute (category 3) to a line.
Failed to attach an attribute (category 8) to a line.
Failed to attach an attribute (category 14) to a line.
Failed to attach an attribute (category 18) to a line.
Failed to attach an attribute (category 29) to a line.
  WARNING: line 80 label: 32 matched another label: 34.
Failed to attach an attribute (category 45) to a line.
Failed to attach an attribute (category 51) to a line.
Failed to attach an attribute (category 52) to a line.
Failed to attach an attribute (category 55) to a line.
Failed to attach an attribute (category 56) to a line.
  Number of lines:   218
  Number of nodes:   215
  Number of areas:   0
  Number of isles:   0
  Number of atts :   45
  Number of unattached atts :   11
  Snapped lines  :   0
Editing category file I have found some category strings have problems
with tilde (system locale is spanish), but this seems not to be related
with failed attachments
#########Output from v.info#################################
Layer:    prov              Date:
Mapset:   PERMANENT         Organization:
DataBase: /var/GRASSDATA/
Title:    ( prov)
Type of Map:  Vector (level: 2)     Number of Categories: 56
                  				    Number of areas:      0
                                     Number of islands:    0
Projection: Latitude-Longitude (zone 0)
N:0  S:0
E:0  W:0
Source date:
Original scale 1:0
     Map threshold: 0.00000
          Comments:
As you can see, region limits are somewhat shocking
g.region vect=prov
##########g.region -p output##################################
projection: 3 (Latitude-Longitude)
zone:       0
datum:      eur50
ellipsoid:  international
north:      0:00:03N
south:      0:00:03S
west:       0:00:03W
east:       0:00:03E
nsres:      0:00:03
ewres:      0:00:03
rows:       2
cols:       2
funny, it isn't? ;-)
After this, d.vect still shows nothing
Running v.llabel doesn't help
I have not run v.alabel since v.info says there are no areas.
Best regards,
Roman
