[GRASSLIST:4067] Re:Basic proj question
Michele
michele.rocc at libero.it
Mon Aug 2 09:17:25 EDT 2004
Labert equal area is not a datum, and you can find it choosing "Other Projection" ( "D" item in the menu) while you setup a new location.
Michele.
> I'm trying to project data from non-wgs84 sources onto the GTOPO30
> DEM. But these data are in Lambert equal area. When I go to set up
> a database in Lambert equal area, the choices for "geodetic datum"
> do not include it, i.e.:
> ok? (y/n) [y]
> Do you wish to specify a geodetic datum for this location?(y/n) [y] y
> Please specify datum name
> Enter 'list' for the list of available datums
> or 'custom' if you wish to enter custom parameters
> Hit RETURN to cancel request
> >list
> Short Name Long Name / Description
> agd66 Australian_Geodetic_Datum_1966
> (australian ellipsoid)
> agd84 Australian_Geodetic_Datum_1984
> and so on. No Lambert equal area, or several others I might name. Does
> this list come from PROJ.4?
> I've compiled GRASS 5.3 with the latest PROJ.4 I could find, and still
> no luck with this. Any idea what I'm doing wrong here? I'm assuming
> that as per the manual one creates two databases and then uses r.proj
> to project the one coordinate system onto the other one.
> Thanks. :^)
> Adios,
> Chris Cornuelle
> bob at xmission dot com
