[GRASSLIST:4070] Re:Basic proj question
C.S. Cornuelle
bob at xmission.com
Mon Aug 2 19:39:56 EDT 2004
Michele,
Hmm, educational. :^)
Thanks, that works.
Thus spake Michele (michele.rocc at libero.it):
> Hi,
> Labert equal area is not a datum, and you can find it choosing "Other Projection" ( "D" item in the menu) while you setup a new location.
> Michele.
> > I'm trying to project data from non-wgs84 sources onto the GTOPO30
> > DEM. But these data are in Lambert equal area. When I go to set up
> > a database in Lambert equal area, the choices for "geodetic datum"
> > do not include it, i.e.:
> > ok? (y/n) [y]
> > Do you wish to specify a geodetic datum for this location?(y/n) [y] y
> > Please specify datum name
> > Enter 'list' for the list of available datums
> > or 'custom' if you wish to enter custom parameters
> > Hit RETURN to cancel request
> > >list
> > Short Name Long Name / Description
> > agd66 Australian_Geodetic_Datum_1966
> > (australian ellipsoid)
> > agd84 Australian_Geodetic_Datum_1984
> > and so on. No Lambert equal area, or several others I might name. Does
> > this list come from PROJ.4?
> > I've compiled GRASS 5.3 with the latest PROJ.4 I could find, and still
> > no luck with this. Any idea what I'm doing wrong here? I'm assuming
> > that as per the manual one creates two databases and then uses r.proj
> > to project the one coordinate system onto the other one.
> > Thanks. :^)
Adios,
Chris Cornuelle
bob at xmission dot com
