[GRASSLIST:4265] Re: Releasing GRASS modules
Benjamin Ducke
benducke at compuserve.de
Fri Aug 27 09:12:07 EDT 2004
On Fri, 27 Aug 2004 00:18:22 +0100 (BST)
Paul Kelly <paul-grass at stjohnspoint.co.uk> wrote:
> On Thu, 26 Aug 2004, Benjamin Ducke wrote:
> > I would like to release some GPL'd GRASS 5.3 modules
> > for spatial predictvie modelling into
> > the GRASS community. My questions are:
> > 1. is there a way to set up a Gmakefile so that HTML
> > manpages are merged into the GRASS documentation index?
> > The way it is right now, the HTML pages get copied into
> > the user's documentation/html directory, but there are
> > no links from the main index.html file so that the user
> > is left to point his webbrowser to the files explicitly.
> No; this index is just maintained manually. Note that all the files in the
> html/html directory are converted into man pages during compilation so
> that you can read them with g.manual. This isn't done for 5.7 (although I
> wish it was), which just has html pages.
OK, so I take it there is no way to merge documentation automatically
for external modules in 5.3.
> > 2. once other people have tried and tested the modules
> > and find them useful, is it possible to include them
> > into the 5.3 CVS, so that people will not have to
> > download the source from my homepage and have to install
> > separately?
> There will be no new modules in the 5.3 CVS before the 5.4.0 release. Do
> the modules use any special features of 5.3 that mean they can't be used
> directly or easily ported to 5.7?
I make use of the site data format for representing the locations of known
objects. It should not be too much work to convert that to vector points
for 5.7 but I will have to find some time to do it.
Does 5.7 still include the site full sites API?
> Perhaps if things drag on for a long time, after the 5.4.0 release the
> modules could be added to the '5.5 CVS', but CVS write access to that is
> going to be closed so you would not be able to commit bugfixes. Better to
> add them to 5.7 I think.
I guess so. In the meantime I might set up a homepage of my own to distribute
my code. In the meantim, if anyone here is really interested in it, contact me
and I will send it to you via email.
Benjamin
