[GRASSLIST:2518] Re: alpha blending
Glynn Clements
glynn.clements at virgin.net
Sun Feb 8 11:24:02 EST 2004
Markus Neteler wrote:
> > I was wondering if there is a trick or even a module which enables
> > transparency on a vector poligon (with rasters I guess you can use a trick
> > with the hue-saturation module). I saw Radim's qgis implementation of
> > GRASS rasters and vectors, including alpha blending
> > (http://mpa.itc.it/radim/qgis/) so I was wandering if something similar
> > is/will be/might be implemented in GRASS
> Hi Francesco,
> once there have been efforts to implement alpha blending into XDriver
> (together with some RGB updates, maps as selectable layers etc):
> Check
> src.todo/display_driver/
I don't see anything in that which relates to alpha blending.
Glynn Clements <glynn.clements at virgin.net>
