[GRASSLIST:2704] Re: stitching geotiffs
Morten Hulden
morten at untamo.net
Fri Feb 20 22:23:16 EST 2004
On Fri, 20 Feb 2004, Richard Greenwood wrote:
> Martin du Saire wrote:
> > Outstanding! Thank you Richard and Glynn. I think I may eventually
> > have to r.patch the individual maps. I was playing around with two maps
> > within a single zone, and the r.stats -a -n map1,map2 output did not
> > reflect what I expected to be the composite of the two (Actually, the
> > numbers made no sense at all). One last question:
> > Without having specific datum in my adjacent zones (14, 16), is there
> > some way to make upper-bound estimates on the amount of distortion
> > resulting from the r.proj method=nearest (the maps are land-use/cover)?
> > Thanks again.
> > Martin
> That's a hard question that I will not try to answer directly. Map
> distortion can involve linear, directional, and/or area distortion. So
> first you have to define which of those are relevant to your
> application. I think in your case the most significant distortion will
> be angular. And I would guess that areas would be most important for
> land use applications. Within a UTM zone I am thinking that area
> distortion is limited to about 0.04% because the central meridian has a
> scale factor of 0.9996 (anyone is welcome to correct me on that). But as
> you move outside the zone, the increase in distortion would not be linear.
> I am kind of a trial-and-error guy, so if it was me, I would simply
> reproject the extreme cases into the target location and see if they
> meet your requirements. Extending UTM zones is not generally considered
> a good practice (although I am guilty of having done it a couple times).
> A better solution might be to create a projection for your project.
For visual checking you can use r.mapcalc to create a raster grid
in one location, then project it into an other location and check
the distorion. e.g.
r.mapcalc testgrid='if((row()%5) && (col()%5))'
will create a grid where every 5th row and column have a different color.
I bet someone has a more sofisticated recipe.
