[GRASSLIST:2725] Problem importing arc info file
Leonardo Lami
leo.lami at katamail.com
Tue Feb 24 06:46:33 EST 2004
Sorry but I have never worked with arc/info files and so i have again
problems.
I have seven files for my dtm layer:
dblbnd.adf
hdr.adf
log
prj.adf
sta.adf
w001001.adf
w001001x.adf
I added:
yllcorner:4675800
xllcorner:1550000
nrows:2492
ncols:2272
cellsize:100
at the bottom of the w001001.adf file but when i run r.in.arc the output
message say:
r.in.arc: ** errors detected in header section **
illegal line in header
"yllcorner:4675800"
"yllcorner" field missing from header
"xllcorner" field missing from header
"nrows" field missing from header
"ncols" field missing from header
"cellsize" field missing from header
"nodata_value" field missing from header
Can't proceed
May be I mismatch the file where I add the header or its format.
Can you help me
Thank you very much
Leonardo Lami
>You can easily add the appropriate six line header from the file
>characteristics
>Leonardo Lami wrote:
> I'm trying to import a arc info file with r.in.gdal, because it is not
> supported by r.in.arc (it has not the header section).
> The command seems work well but when I display the raster only a little part
> is right and the rest of the cells of the raster have the value of the
> category set to 0.
> Can someone help me?
> Thank you
> Leonardo
