[GRASSLIST:3979] Re: [GRASS5] [bug #2545] (grass) vect32 fails to build
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Wed Jul 21 06:42:56 EDT 2004
>The patch below shows how I propose to fix this. I think
>src/CMD/gmake.sh should be changed so that $(OBJARCH) is preprended
>at the beginning of a path leading to a .o file rather than
>immediately preceding the filename.
>i.e. Vlib/open.o becomes $(OBJARCH)/Vlib/open.o rather than
>Vlib/$(OBJARCH)/open.o as at present.
Paul
Your patch resolve bug #2545 and bug #2547. Now is possible to create
libvect_combined.a
>This should fix things for both the alternate and gmake systems.
>It will also cause problems for badly written or non-standard
>Gmakefiles. The only one I came across is for r3.null and I will fix
>that by building r3.null and r3.mask from the same directory (cf.
>r.mapcalc and r3.mapcalc are built from the same directory).
>But there might also be problems with non-standard Gmakefiles in
>add-on modules people have written themselves I suppose. But
>probably not very likely. So I just wanted to post this here for a
>while for comments before committing the changes.
>The r.terraflow Gmakefile also needs fixed so it will work with both
>build systems. It has a related but different problem with using
>sub-directories.
Yes the only problem is in r3.null like you say...
Thanx
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (res.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
Download GRASS for MAC OS X:
http://wwwamb.bologna.enea.it/forgrass/
