[GRASSLIST:3720] Re: v.in.ogr and v.out.ogr
Radim Blazek
blazek at itc.it
Sat Jun 19 03:41:34 EDT 2004
On Saturday 19 June 2004 01:36, cirgeo_admin wrote:
> Hi all grass users,
> Firstly thanks to Radim for clearing up for me the fact that I (obviously)
> have to compile gdal-ogr with pg support if I want to use it for postgis
> import/export.
> I am using a lot the new module v.out.ogr and v.in.ogr to import export
> postgis: I came up with the following observations:
> the following command gave me an error:
> v.out.ogr input=MA_finale dsn="PG:host=localhost dbname=EvA" layer=mamma
> field=1 format=PostgreSQL
> ERROR 1: AddGeometryColumn failed for layer mamma, layer creation has
> failed. ERROR: Cannot create layer
Is it valid PostGIS database? Can you create table with geometry in psql?:
create table test (geom geometry);
> If I IMPORT from a valid postgis database everything goes fine but the
> attributes are not editable... is that normal??
In d.what.vect? Did you notice -e flag?
Radim
