[GRASSLIST:2949] Re: [GRASS5] FLY through in NVIZ
Andrew
selkiesdad at twcny.rr.com
Mon Mar 15 05:56:12 EST 2004
The imagemagick tools contain a function that will convert png sets to
mng (mpg-like animation). I believe it is called 'convert'
Hamish wrote:
>>How can I make a fly through from NVIZ. I tried NVIZ
>>and could make only small animations. Thankyou in advance.
>Check out the NVIZ tutorial.
>http://grass.baylor.edu/gdp/nviz/nviz_tut.html
>especially: Basic Animation and Key frame Animation sections.
>This has been updated for GRASS 5.3 & 5.7.
>Also try compiling "d.nviz" in src.contrib/GMSL/
>If you make a symlink from 'ppmtompeg' to 'mpeg_encode' somewhere in
>your $PATH, r.out.mpeg will work, but this is MPEG-1 and not that great.
>For more MPEG-1 and MPEG-2 support you can use The GIMP; or for high
>quality & modern MPEG-4 and others try mplayer's mencoder or the ffmpeg
>encoder. For high quality animations you can play in any web browser
>(limited to a few hundred frames) use "gifsicle".
>The netpbm programs are useful and will be needed between steps...
>If anyone knows how to do animated PNGs I'd be interested in how that
>is done..?
>Hamish
