[GRASSLIST:4708] v.out.ogr
Eliot Cline
eliot at gospatial.com
Thu Nov 4 02:11:03 EST 2004
Hello all,
I am using Grass57 to convert some raster maps to vector. I used the r.to.vect command to generate some polygons from one of the categories in a raster layer. I then wanted to export these polys to a shapefile to clean them up in another software package. For some reason v.out.ogr runs very slowly when exporting areas and after a while stops processing altogether. No such problems when exporting area boundaries, but I would really like to create a polygon shapefile. Has anyone seen this problem before? Any suggestions for an alternative way to get the data out of Grass and into a shapefile?
Thanks in advance,
Eliot Cline
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20041104/64ace22e/attachment.html
