[GRASSLIST:4890] Re: Using FileMaker Pro 7.0 as a DBMS
Kurt Springs ferret_bard at mac.com
Sun Nov 21 16:54:09 EST 2004
Thanks Nick,
Unfortunately, I will have to wait until version two comes out to use it
with Filemaker Pro 7 :-P .  I have  another program that can translate
FM7.  I just need access to a Windows machine with Active Perl to run
the scripts to make the final translation :-P :-P .  Maybe someone can
writ a GRASS module that translates directly from .fp7 to the GRASS
database ;-) .
I hope to have a report I yesterday's battle on the list tonight.
Kurt
Nick Cahill wrote:
> Just saw an announcement of this: Filemaker to SQL Sync
> (http://www.garrison.com.au/products/fmsql_synch.html). It would be
> pathetic to have to pay $130 for something to synchronize your
> filemaker database with much higher powered, open-source software; but
> if you can't get FM to work with GRASS and want to do basic data entry
> etc. in FM, I wonder if it would be worth checking this out?
> Good luck - again, I'm surprised nobody has done this before.
> Nick Cahill
