[GRASSLIST:4891] Re: remove small islands
Markus Neteler
neteler at itc.it
Sun Nov 21 17:07:00 EST 2004
For higher precision, you may use:
GRASS 5.7:
- r.to.vect
- v.clean
rmarea - remove small areas, the longest boundary with adjacent area is removed
Markus
On Sat, Nov 20, 2004 at 01:45:39PM -0200, Sandro Klippel wrote:
> r.neighbors method=mode
> Em Sáb 20 Nov 2004 13:00, Martin Wegmann escreveu:
> > hello,
> > I tried to remove islands in a classified raster image which are smaller
> > than 1 -2 pixel.
> > Is there any command which removes small islands and assigns the prevailing
> > value of the surrounding area to this island?
> > r.neighbors might be what I want if there would a
> > method=dominant/prevailing value, method=average just smoothed the image.
> > any ideas? thanks in advance, Martin
> Instituto IGARÉ
> http://geocities.yahoo.com.br/institutoigare
> e-mail: institutoigare at yahoo.com.br
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
