[GRASSLIST:4488] grass53 installation
jun liang liangj at email.unc.edu
Thu Oct 7 14:08:55 EDT 2004
Ian,
  Thanks. You may be right.
  I have done another test - I have copied four files from university's
installation location (it works):
mon.start, mon.status, mon.stop and mon.which (my compilation lost these
four files), which are version grass501, to my grass53 /etc/.
   The amazing thing here is - now I can run grass53, using four mon.*
files from grass-501! So far only one function failed - I could not set
my region - but can display, zoom in and zoom out.
    When I try to set region, I will get this from my tcltkgrass window:
ld.so.1: g.region: fatal: libproj.so.0: Killed
Jun
I am not absolutely sure about this, but I think you need to have
administrative permissions (i.e. root) in order to run GRASS and to
install it.  I am not a programmer, so I don't know why, but everything
I have seen on this list the last few years indicates that root
privelages are required.
Good luck,
Ian
On Oct 6, 2004, at 12:49 PM, jun liang wrote:
> This is my first time trying to compile grass.
> I do not have root permission and I want to install grass53 in my
> personal space.
> I download grass53 source code to /scratch2/grass/grass-5.3.0/
> This is my configure option setting:
> ./configure --prefix=/afs/isis/depts/geog/course1/grass/
> --bindir=/afs/isis/depts/geog/bin
> --with-zlib-includes=/afs/isis/pkg/zlib/install/include
> --with-zlib-libs=/afs/isis/pkg/zlib/install/lib
> --with-jpeg-includes=/afs/isis/pkg/jpeg/include
> --with-jpeg-libs=/afs/isis/pkg/jpeg/lib
> --with-tiff-includes=/afs/isis/pkg/tiff/include
> --with-tiff-libs=/afs/isis/pkg/tiff/lib --without-tiff
> --with-png-includes=/afs/isis/pkg/libpng/include
> --with-png-libs=/afs/isis/pkg/libpng/lib --without-png --enable-w11
> --with-x --without-postgres --without-opengl --without-odbc
> --with-fftw-includes=/afs/isis/pkg/fftw/include
> --with-fftw-libs=/afs/isis/pkg/fftw/lib
> --with-proj-includes=/afs/isis/depts/geog/pkg/proj/include
> --with-proj-libs=/afs/isis/depts/geog/pkg/proj/lib
> --with-gd-includes=/afs/isis/pkg/gd/include
> --with-gd-libs=/afs/isis/pkg/gd/lib
> --with-tcltk-includes="/afs/isis/pkg/tcl/include
> /afs/isis/pkg/tk/include" --with-tcltk-libs="/afs/isis/pkg/tcl/lib
> /afs/isis/pkg/tk/lib"
> And result:
>   Build Mechanism:           gmake
>   Source directory:          /scratch2/grass/grass-5.3.0
>   Build directory:           /scratch2/grass/grass-5.3.0
>   Installation directory:
> /afs/isis/depts/geog/course1/grass//grass53
>   C compiler:                gcc -g -O2  -D__W98__
>   C++ compiler:
>   FORTRAN compiler:          g77
>   NVIZ:                       no
>   X11 support:                yes
>   JPEG support:               yes
>   TIFF support:               no
>   PNG support:                no
>   Tcl/Tk support:             yes
>   PostgreSQL support:         no
>   OpenGL(R) support:          no
>   SGI IRIS GL support:        no
>   ODBC support:               no
>   FFTW support:               yes
>   BLAS support:               no
>   LAPACK support:             no
>   Motif support:              no
>   FreeType support:           no
>   GLw support:                no
>   NLS support:                no
>   Readline support:           no
>   C++ support:                no
>   External PROJ.4 support:    yes
>   GDAL/OGR support:           yes
> Then I run
>> make
>> make install
> error.log:
> GRASS GIS compilation log
> Start of compilation: Fri Oct  1 23:23:27 EDT 2004
> Errors:
> Compilation error in module: src/display/d.mon (ignored)
> Compilation error in module: src/raster/r.in.gdal (ignored)
> Compilation error in module: src/raster/r.in.png (ignored)
> Compilation error in module: src/raster/r.mapcalc3 (ignored)
> Compilation error in module: src/raster/r.out.png (ignored)
> Compilation error in module: src/raster/r.tiff (ignored)
> Compilation error in module: src/display/devices/windows (ignored)
> End of compilation:   Fri Oct  1 23:47:05 EDT 2004
> DONE generating GRASS GIS binary code
> I can run grass53, but could not get d.mon start=x0 working for me.
> And I found out the reason is - mon.start was not there (under /etc).
I
> can only find
> mon.list, mon.select and mon.release. Is there any way I can fix this?
> Or do I have
> to have root access to be able to compile grass53? Any help and
> suggestion will be
> appreciated. Thanks in advance.
> Jun
> <liangj.vcf>
Type: application/defanged
Desc: Card for jun liang
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20041007/6418f195/liangj.bin
