[GRASSLIST:4504] dxf layer transformation
Kirk R. Wythers
kwythers at umn.edu
Mon Oct 11 14:16:14 EDT 2004
I could use some advice geocoding a .dxf file. Bellow are the steps I
have taken thus far:
I have an xy dxf map imported into grass following Neteler and Mitasova
2004. I brought in the single dxf file with v.in.dxf -a, which created
approximately 50 ascii files (one for each layer in the original dxf
file). I then went ahead and converted the ascii layers to grass binary
files with v.in.ascii -s . Now I need to set ground control points and
do the transformation. However, it seems terribly repetitive to set
GCPs for each layer and do individual transformations for each. In
addition it will be very problematic to find accurate ground control
points from a rectified raster of the same area due to the fact that
the features displayed in some of the vector layers don't show up well
in the raster.
Is there some way way to group the vector layers together and transform
them all at once? This would allow me to chose the layer with features
that would for good ground control points.
Kirk
