[GRASSLIST:4558] Re: existing libgdal.so.1 library not found by startup script ps.map
Maciek Sieczka werchowyna at pf.pl
Sat Oct 16 09:02:14 EDT 2004
> Even after installing the libgdal.so.1 library in the folder usr/bin/
usually libs are kept in /lib, /urs/lib and /usr/local/lib
if you install your libs into /usr/local/lib then add this path to the
/etc/ld.so.conf and run 'ldconfig' as root
Maciek
