[GRASSLIST:4671] Re: Compiling Grass
Thu Oct 28 14:48:47 EDT 2004
Paul Kelly wrote:
> > Anyway, I installed the now compiled 5.3 and then tried gdal. It still
> > cannot find the grass libraries, I'm telling it where its been installed,
> > trying :
> You don't need GRASS support in GDAL. That is only if you want GDAL to be
> able to read GRASS databases for some third party application.
Almost. The r.out.gdal script in 5.7 relies upon gdal_translate being
able to read GRASS databases, i.e. using a version of GDAL which was
built with GRASS support.
OTOH, r.in.gdal doesn't require GDAL to have GRASS support.
