[GRASSLIST:4673] Re: Compiling Grass
David Bannon D.Bannon at vpac.org
Thu Oct 28 18:30:05 EDT 2004
Thanks Paul, you have clarified a couple of things for me.
> r.mapcalc is quite important; post the errors you are getting to the
> developers' mailing list if  you need help getting it working.
Check, I assumed because it compile proceeded it was unnecessary. Will go
back to it and chase.
> >  ... gdal-config....
> It should come with GDAL when you install it. Have you installed GDAL
> properly?
Yes, as far as I know. I'll have another look.
> You don't need GRASS support in GDAL. That is only if you
> want GDAL to be
That's an eye opener !
> > 5.3 install that affects the 5.7 ?
> You don't need to compile or install 5.3 to use 5.7. You just
> need the
> source code. The 5.7 CVS doesn't contain the source code for
> those modules
> that haven't changed between 5.3 and 5.7.
Right ! Now, does that mean that I should untar the source into the same
directory ? And in what order, first 5.3 and the overwrite with 5.7 ??
(Note, I'm not using the cvs of 5.7, it's the 'release' from the web site.
> Hope this points you in the right direction
Certainly going a long way towards it!
David
