[GRASSLIST:4413] Re: mode()
Maciek Sieczka
werchowyna at pf.pl
Fri Sep 24 12:48:29 EDT 2004
Hi All!
Still no any answer so let me bug you a little more. I was thinking of
putting a bug report on this issue but first of all I don't know how to
describe it because it's weird and secondly COULD ANYBODY CHECK IF YOU CAN
REPRODUCE THE ERROR so I could make sure if I'm not a separated case? It's
hard for me to believe that such a nasty bug would survive in r.mapcalc and
I'm ready to be convinced that it's all my fault somehow.
In a given region:
projection: 0 (x,y)
zone: 0
north: 100
south: 0
west: 0
east: 100
nsres: 1
ewres: 1
rows: 100
cols: 100
I'm having adventures like this:
GRASS:~ > r.mapcalc 'map_mod=mode(2)'
100%
GRASS:~ > r.mapcalc 'map_mod=mode(2,2)'
100%
Segmentation fault
GRASS:~ > r.mapcalc 'map_mod=mode(2,2,2)'
100%
GRASS:~ > r.mapcalc 'map_mod=mode(2,2,2,2)'
100%
Segmentation fault
GRASS:~ > r.mapcalc 'map_mod=mode(2,2,2,2,2)'
100%
GRASS:~ > r.mapcalc 'map_mod=mode(2,2,2,2,2,2)'
100%
mv: nie można wykonać stat na
`/home/gr/home/grorient/wewn/.tmp/localhost/1197.0': No such file or
directory
ERROR: closecell: can't move
to cell file /home/grassdata/orient/wewn/cell/map_mod
GRASS:~ > r.mapcalc 'map_mod=mode(2,2,2,2,2,2,2)'
100%
`/home/grorient/worient/wewn/.tmp/localhost/1201.0': No such file or
directory
GRASS:~ > r.mapcalc 'map_mod=mode(2,2,2,2,2,2,2,2)'
100%
where "mv: nie można wykonać stat na" means "mv: cannot execute stat on"
beautifull, isn't it?
or take a look at this:
GRASS:~ > r.mapcalc 'map_mod=mode(1,2,3,4)'
100%
GRASS:~ > r.mapcalc 'map_mod=mode(1,2,3)'
Segmentation fault
GRASS:~ > r.mapcalc 'map_mod=mode(1,2)'
Segmentation fault
GRASS:~ > r.mapcalc 'map_mod=mode(1)'
Segmentation fault
GRASS:~ > r.mapcalc 'map_mod=median(1)'
Segmentation fault
GRASS:~ > r.mapcalc 'map_mod=median(1,2)'
Segmentation fault
or this one:
GRASS:~ > r.mapcalc 'map_mod=mode(5,5)'
Segmentation fault
GRASS:~ > r.mapcalc 'map_mod=mode(5,5,5)'
Segmentation fault
GRASS:~ > r.mapcalc 'map_mod=mode(5,5,5,5)'
100%
GRASS:~ > r.mapcalc 'map_mod=mode(5,5,5,5,5)'
100%
GRASS:~ > r.mapcalc 'map_mod=mode(5,5,5,5,5,5)'
100%
Segmentation fault
These listings come from a cvs Grass 5.3 (grass53_exp_2004_08_21) built from
source on a Mandrake 9.2 but I've had this fun in a precompiled 5.03 too.
Looking forward to any reply.
Maciek
