[GRASSLIST:6514] Re: m.proj s.in.ascii s.to.rast
Markus Neteler neteler at itc.it
Sun Apr 17 15:52:20 EDT 2005
On Fri, Apr 15, 2005 at 12:11:22PM -0500, Martin du Saire wrote:
> Hi,
> I just installed GRASS6.0, the installation was a lot easier (as I recall)
> than installing 5.0 a year ago.
> Last time I worked with GRASS (Feb 2004), I was trying to calculate the
> landcover statistics in a 500km radius around a research site using the
> NLCD from USGS:
> a)  I used m.proj2 to convert my site location to the appropriate
> projection.
> b)  defined the site with s.in.ascii, and converted it to a raster using
> s.to.rast.
> c)  created the buffer zone using r.buffer
> d)  patched the landcover map in the buffer zone with r.patch -z
> e)  calculated statistics with r.stat -c
> What happened to m.proj(2), s.in.ascii, and s.to.rast?
> I gather these commands no longer exist. In that case I need some help
> figuring out how to do this in 6.0.
Please have a look at
 http://grass.gdf-hannover.de/twiki/bin/view/GRASS/ModulePortingList#Miscellaneous_Commands
to find out what happend to these modules.
Markus
