[GRASSLIST:6611] Re: Error in startup script: ps.map:
    Glynn Clements
    glynn at gclements.plus.com
    Sat Apr 23 22:22:33 EDT 2005
John Francis Lee wrote:
> I have on my screen :
> GRASS 6.0.0 (temp):~/GRASS > Error in startup script: ps.map: error
> while loading shared libraries: libgdal.so.1: cannot open shared object
> file: No such file or directory
GDAL is a mandatory dependency for GRASS 6.x. You can obtain it from:
	http://www.gdal.org/
If you already have it, and it's installed in /usr/local/lib, check
that /usr/local/lib is listed in /etc/ld.so.conf; if it isn't, add it
then run "ldconfig".
