[GRASSLIST:7888] joining attribute tables of points and areas???
Sascha Wichmann
swi.potsdam at web.de
Fri Aug 12 12:46:59 EDT 2005
Hello,
I've the following problem.
Given are two vector maps (one with POINTS and one with AREAS).
The result should be a vector map (POINTS) containing the attributes
of the original points and of the areas in that the points lie in.
<v.overlay> obviously doesn't work here. I also tried <v.select>, but
that's also not woorking, since this function doesn't join the attribute
tables.
Does anybody has an idea?
Thanks in advance for your answers
Sascha
