[GRASSLIST:7891] Re: r.proj takes a very long time / does not complete
Morten Hulden
morten at untamo.net
Sat Aug 13 12:14:13 EDT 2005
Jason Horn wrote:
> I have a long-standing problem with r.proj. I have never been able to
> complete a successful re-projection of a raster file. For example, I am
> trying to pull in a raster file from a location that is lat-lon, WGS84
> into a location that is state-plane meters, NAD83. The raster grid is
> relatively small, 1000 cols by 830 rows. I start r.proj like this:
> r.proj input=KEWX20040710_025420 location=TX_ll_WGS84 mapset=PERMANENT
> output=proj1 method=nearest
> Although my CPU stays pegged at close to 100% usage, the progress bar
> never moves forward and nothing happens, even if I leave it for many
> hours. Can anyone tell me what's going on here?
In order to help you I would like to see:
1) The PROJ_INFO file for your latlon location
2) The cellhd file of the KEWX20040710_025420 map in the latlon location
3) The PROJ_INFO file for your NAD83 location
4) The WIND file for your NAD83 location
