[GRASSLIST:7952] Re: r.proj takes a very long time / does not complete
Ian MacMillan ian_macmillan at umail.ucsb.edu
Wed Aug 17 14:57:30 EDT 2005
A rule of thumb that I use is that 1 arc-second equals 30 meters.  This
is close enough for the work that I do.  It varies away from the
equator, and I am not sure if it is exactly 30 meters, it probably
depend on the type of ellipsoid used for the earth.  Hope this helps.
-Ian
On Aug 17, 2005, at 11:41 AM, Jason Horn wrote:
> Ian, Morten,
> Thanks so much for pointing out the problem.  I have seceded in
> projecting the raster layer, with the help of the v.in.region box
> trick.  I have set the resolution to an approximation of what I think
> is right.  However, how can I really match the resolution in the new
> state plane location to the resolution from the old lat-lon location?
> - Jason
> On Aug 15, 2005, at 5:25 PM, Ian MacMillan wrote:
>> A simple way to do this is to make a vector box of your region in the
>> first location using v.in.region.  Go to your new location, v.proj
>> that vector in, and set your region to the new vector.  Then use
>> r.proj on the raster you want to project.  You will still have to set
>> the resolution on your own though.  Hope this makes sense.
>> -Ian
>> On Aug 15, 2005, at 2:14 PM, Morten Hulden wrote:
>>> No wonder it takes forever. Your output location has 527482690275
>>> cells (847325 x 622527) to project.
>>> You should adjust the boundaries or resolution of your NAD83
>>> location to something more reasonable. Before running r.proj try to
>>> set a resolution value that roughly matches the resolution of your
>>> input map (g.region res= ), e.g. something like 1000 m.
>>> Don't know about boundaries for your location (TX unknown area to
>>> me) but you may want to check those as well. No need to cover more
>>> than what is necessary.
>>> rgds
>>> Morten
>>> Jason Horn wrote:
>>>> Morten,
>>>> Thanks for looking at this for me.  Below are the files you asked
>>>> for.
>>>> PROJ_INFO for the source lat-lon location:
>>>> datum: wgs84
>>>> towgs84: 0.000,0.000,0.000
>>>> proj: ll
>>>> ellps: wgs84
>>>> cellhd file for  KEWX20040710_025420:
>>>> proj:       3
>>>> zone:       0
>>>> north:      34:00:17.832478N
>>>> south:      25:11:59.799175N
>>>> east:       92:43:25.599215W
>>>> west:       103:19:56.000785W
>>>> cols:       1000
>>>> rows:       830
>>>> e-w resol:  0:00:38.190402
>>>> n-s resol:  0:00:38.190402
>>>> format:     -1
>>>> compressed: 1
>>>> PROJ_INFO file for the destination NAD83 location:
>>>> name: Lambert Conformal Conic
>>>> datum: nad83
>>>> proj: lcc
>>>> ellps: grs80
>>>> a: 6378137.0000000000
>>>> es: 0.0066943800
>>>> f: 298.2572221010
>>>> lat_0: 31.1666670000
>>>> lat_1: 27.4166670000
>>>> lat_2: 34.9166670000
>>>> lon_0: -100.0000000000
>>>> x_0: 1000000.0000000000
>>>> y_0: 1000000.0000000000
>>>> WIND file for the destination NAD83 location:
>>>> proj:       99
>>>> zone:       0
>>>> north:      1196061
>>>> south:      573534
>>>> east:       1563147
>>>> west:       715822
>>>> cols:       847325
>>>> rows:       622527
>>>> e-w resol:  1
>>>> n-s resol:  1
>>>> top:        1
>>>> bottom:     0
>>>> cols3:      847325
>>>> rows3:      622527
>>>> depths:     1
>>>> e-w resol3: 1
>>>> n-s resol3: 1
>>>> t-b resol:  1
>>>> Thanks again!
>>>> - Jason
>>>> On Aug 13, 2005, at 12:14 PM, Morten Hulden wrote:
>>>>> Jason Horn wrote:
>>>>>> I have a long-standing problem with r.proj.  I have never been
>>>>>> able to complete a successful re-projection of a raster file.
>>>>>> For  example, I am trying to pull in a raster file from a
>>>>>> location that  is lat-lon, WGS84 into a location that is
>>>>>> state-plane meters,  NAD83.  The raster grid is relatively small,
>>>>>> 1000 cols by 830  rows.  I start r.proj like this:
>>>>>> r.proj input=KEWX20040710_025420 location=TX_ll_WGS84
>>>>>> mapset=PERMANENT output=proj1 method=nearest Although my CPU
>>>>>> stays  pegged at close to 100% usage, the progress bar never
>>>>>> moves  forward and nothing happens, even if I leave it for many
>>>>>> hours.   Can anyone tell me what's going on here?
>>>>> In order to help you I would like to see:
>>>>> 1) The PROJ_INFO file for your latlon location
>>>>> 2) The cellhd file of the KEWX20040710_025420 map in the latlon
>>>>> location
>>>>> 3) The PROJ_INFO file for your NAD83 location
>>>>> 4) The WIND file for your NAD83 location
What happens if a big asteroid hits Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad.
  - Dave Barry
This message has been scanned by anti-virus software.
