[GRASSLIST:8025] r.in.gdal -> segfault
Stefan Istvan
stefi at geohidroterv.hu
Tue Aug 23 03:24:53 EDT 2005
Hello!
I tried to import a scanned map using the r.in.gdal module in the
following way:
I created a temporary x-y location larger than the scanned map, then
issued the "r.in.gdal input=filename ouput=nameofrastermap" command. It
results in segmentation fault. I tried to set the debug level higher,
but there are no other error messages.
The scanned map is in a jpg file. I have only read rights to this file,
but I don't think it's problem.
I use grass 5.0.3 version.
Any idea what could be the problem?
Thank you in advance,
Istvan
