[GRASSLIST:8031] Re: Oblique Mercator Projection in GRASS
Morten Hulden
morten at untamo.net
Tue Aug 23 13:58:56 EDT 2005
Dave Kindem wrote:
> From what I can tell, the Proj4 OMERC program accepts parameter
> information in a two ways:
> --the two point method and
> --the central point and azimuth method.
> Currently, the GRASS seems to accept only two point information, and
> the State of Michigan publishes central point and azimuth parameters.
> Is there a way to set up an OMERC-based location within GRASS using the
> data I have? Or, alternatively, can the OMERC interface be modified to
> accept central point and azimuth parameters in a future release?
Not quite sure, but I think this restriction only concerns the g.setproj
program, normally used only when the location is created. After creating
an omerc-location you should be able to edit the PROJ_INFO file to
conform to the other method.
Remove the lines starting with lon_1, lon_2, lat_1 and lat_2 and instead
add two lines with your central point and azimuth parameters:
lonc: <central point longitude>
alpha: <azimuth value>
Don't do this if you already have imported data into your location -
create another location for testing.
After this change [rv].proj tools /should/ work as normal.
Please let us know if this worked or what error messages you get.
rgds
Morten
