[GRASSLIST:9422] New Grass 6.1.cvs for OS X with new features
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Mon Dec 12 06:00:53 EST 2005
Hi all
It's available for all Mac OS X users new GRASS 6.1.cvs version
(051210) with new features (14.7 MB):
http://wwwamb.bologna.enea.it/forgrass/downloadcvs.htm
New features in start application:
the preferences are saved;
check update;
more menu up;
disable start.
The last one is useful to start Grass immediately with your preferences saved.
You can download the xcode project of start application at the same site.
Inside grass (in /scripts folder) there is a small script inside to
open qgis and enable grass tools.
No more terminal to change links inside qgis.
My suggestion is to duplicate qgis application in another folder: one
qgis normal and one for grass.
This script is opened from a menu voice in Gis Manager (Ext > Open
QGIS application) or from terminal entering:
grass 6.1.cvs > d.qgis &
and after you have to select your qgis application anywhere in your
Hard Disk and press Run.
Read the help about the differences when you use X11 or OS X (Aqua)
version of GIS Manager.
You can view this script d.qgis:
http://wwwamb.bologna.enea.it/forgrass/files/d.qgis.txt
I don't know if it's useful for other platforms.
This script create 2 links for 2 libraries inside qgis (libproj and
libgdal) and if you have installed a gdal with geos support also 1
link for libgeos. You can make these changes only the first time that
you run this script.
This script works with last Grass 6.1.cvs (051105 or higher) and QGIS
0.7.4 or higher and Mac OS X 10.3 or higher.
You also can try the new libraries (37.1 MB) for grass with last gdal
(1.3.1) with geos support at:
http://wwwamb.bologna.enea.it/forgrass/files/grasslib_20051121.pkg.zip
These libraries are only for Mac OS X 10.3 or higher.
Grass 6.1.cvs works on Mac OS X 10.2 or higher.
In Mac OS X 10.2.x you can use old Grass 6.0.0 libraries.
Please report any problem.
Bye
__________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
ENEA - Ente Nazionale per le Nuove Tecnologie, l'Energia e l'Ambiente
ENEA - The Italian Agency for New Technologies, Energy and the Environment
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051212/3ebe6c8e/attachment.html
