[GRASSLIST:9451] merging db tables
Kirk R. Wythers kwythers at umn.edu
Tue Dec 13 16:46:12 EST 2005
I have a text file that I want to "merge" with an existing db table
(there is a common column in both the vector table and the ascii
file). Is there some kind of merge command that would work within
grass, or should I export the vector, merge, then reimport the merged
vector with v.in.ascii?
Any suggestions would be much appreciated.
Kirk
