[GRASSLIST:5664] Re: Compare GRASS5 and GRASS6
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Feb 7 09:31:01 EST 2005
On Mon, 7 Feb 2005, Michael Barton wrote:
>> 2. Autovectorisation from a bitmap image, which was
>> good in GRASS5.3 is missing in GRASS5.7, is it
>> available in GRASS6?
> Again, what is the name of the module you are talking about? Until you tell
> us the name of the module that needs porting, we can't do much about it.
Yes r.line (vector lines), r.poly (vector areas) and r.to.sites (vector
points) have all been merged into r.to.vect. Though you may still need to
run r.thin beforehand if vectorising lines.
