[GRASSLIST:5748] Re: beta2: problems with shape import and v.surf.rst
Moritz Lennert mlennert at club.worldonline.be
Sat Feb 12 17:00:45 EST 2005
On Sat, February 12, 2005 21:13, Carlos Henrique Grohmann said:
> I have just compiled grass6beta2, and I'm with some problems with shape files.
> I have this large topographic shape, with a dbf of about 35Mb. Ehrn I try to
> import it into grass, the dbf table is not created! why? is there a size
> limitation?
Do you see any error messages ? Are you sure it is not created (where did you
look) ?
> another one: I can't use v.surf.rst.
> when I call it, it gives me an error msg, and this in my terminal:
>> ERROR: Required parameter <input> not set:
>>     (Name of the vector file with input data).
Well, the message seems quite obvious to me: you have to give it a vector file
name as input and apparently you didn't...
Moritz
