[GRASSLIST:5922] Re: 6.0.0beta2 configure failure
    Rich Shepard
    rshepard at appl-ecosys.com
    Sun Feb 27 16:35:09 EST 2005
On Sun, 27 Feb 2005, Tom Russo wrote:
> It should be enough to first build GDAL without GRASS support, then build
> GRASS with GDAL support, then rebuild and install GDAL *with* GRASS
> support by pointing the configure script at your installed GRASS binaries
> directory.  The shared library should then be OK, and r.out.gdal should
> work without recompiling GRASS.
Tom,
   I thought of doing this but have not yet done so.
Thanks,
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
<http://www.appl-ecosys.com>   Voice: 503-667-4517   Fax: 503-667-8863
