[GRASSLIST:5483] Re: GRASS raster to ArcGIS?
    Markus Neteler
    neteler at itc.it
    Sat Jan 22 04:29:02 EST 2005
GRASS raster -> other GIS:
A good (rather new) option to exchange data is to go via standard
raster files such as GeoTIFF etc.
GRASS 6 provides a script 'r.out.gdal' which writes valid
GeoTIFFs (also other formats, see:
 http://grass.itc.it/grass60/manuals/html60_user/r.out.gdal.html
It is a wrapper script around the excellent 'gdal_translate' tool.
Requirements are GDAL to be installed, with GRASS support
compiled in (GDAL now comes with an own driver/plugin which
links to the GRASS 6 libraries, no need to compile the
dated 'libgrass').
Configuration scripts (especially for the GRASS/GDAL plugin)
I can make available.
SuSe users may go here for SRPMs/binary RPMS:
 http://www.gdf-hannover.de/software/suse/9.1/
Regards
 Markus Neteler
On Fri, Jan 21, 2005 at 06:07:29PM -0500, William W. Hargrove wrote:
> A colleague with whom I've tried to exchange a tarfile of a GRASS mapset
> says that the venerable old GISDBASE env variable/"imagegrid" method of
> transferring files no longer seems to work with the new ArcGIS (and this is
> all that he has).
> If true, ESRI has actually *removed* functionality with this latest product.
> Can anyone verify or correct this?
> Any other suggestions for GRASS raster to Arc grid transfers?
> Thanks,
> Bill H.
> William W. Hargrove                     hnw at fire.esd.ornl.gov
> Environmental Sciences Division         (865) 241-2748
> Oak Ridge National Laboratory           (865) 574-4665 (fax)
> P.O. Box 2008, M.S. 6407                http://research.esd.ornl.gov/~hnw
> Oak Ridge, TN  37830-6407               FedEx/UPS, use "Bethel Valley Rd."
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
