[GRASSLIST:5543] v.in.ascii doesn't work on my computer
Robert S. Nuske
rnuske at gwdg.de
Thu Jan 27 11:51:25 EST 2005
Dear Grass-Listers,
after consulting other Grass users it seems that I am the only one, who can
not read in ascii files with v.in.ascii. The same procedure (see below) works
perfectly on other computers (Debian too), but not on mine. I tried grass57,
grass60 and grass60cvs (all compiled from source). It's all the same.
I have no clue what I am doing wrong, so all hints are more than welcome.
cheers,
robert
Here is what I did:
I used emacs to write following Coordinates in to the file test.txt.
> cat test.txt
599251|4927066
599090|4926953
599097|4926472
599280|4925969
599863|4926391
599849|4926841
> cat test.txt | v.in.ascii fs='|' out=points6 x=1 y=2
Maximum input row length: 15
Maximum number of columns: 2
Minimum number of columns: 2
Building topology ...
0 primitives registered
0 areas built
0 isles built
Attaching islands: Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
