[GRASSLIST:5547] Re: v.in.ascii doesn't work on my computer
Hamish
hamish_nospam at yahoo.com
Thu Jan 27 15:32:06 EST 2005
> after consulting other Grass users it seems that I am the only one,
> who can not read in ascii files with v.in.ascii. The same procedure
> (see below) works perfectly on other computers (Debian too), but not
> on mine. I tried grass57, grass60 and grass60cvs (all compiled from
> source). It's all the same.
> I have no clue what I am doing wrong, so all hints are more than
> welcome.
Can you enter the command:
g.gisenv set="DEBUG=5"
then run the v.in.ascii command
then to turn debugging messages back off:
g.gisenv set="DEBUG=0"
That might give some more clues as to what is happening internally.
> > cat test.txt | v.in.ascii fs='|' out=points6 x=1 y=2
> Maximum input row length: 15
> Maximum number of columns: 2
> Minimum number of columns: 2
> Building topology ...
> 0 primitives registered
> 0 areas built
> 0 isles built
> Attaching islands: Attaching centroids: Topology was built.
> Number of nodes : 0
> Number of primitives: 0
> Number of points : 0
> Number of lines : 0
> Number of boundaries: 0
> Number of centroids : 0
> Number of areas : 0
> Number of isles : 0
Hamish
